Date/Time: Fri, 13 Nov 2026 21:24:49 +0000
Should Sierra be running 24/7
View Count: 635
[2022-12-01 21:50:09]
User449884 - Posts: 237
Is it preferable to have Sierra run 24/7 for performance purposes? Any upside to that?
[2022-12-01 23:30:34]
There are only a few reasons to keep Sierra Chart running 24/7. Here are the ones we can think of:
- You have client side orders still open.
- You use data from either CQG or Rithmic which does not back fill very well, so you need to accumulate the data in real-time.
- You want to run a trading algorithm 24/7.
- You load a LOT of data in your charts and it takes longer than you want to load the data each morning.
Date Time Of Last Edit: 2022-12-01 23:31:20
