Date/Time: Fri, 13 Nov 2026 21:24:55 +0000
Auto-send market order on Rejected stop attached order - yes
View Count: 1196
| [2022-12-01 19:42:38] |
| User913668 - Posts: 1 |
This function is under trade/trade settings. Will marking yes on this function solve the issue I had this morning at 10:00 am EST. This was the ISM Manufacturing PMI announcement which was very volatile in the first 10-15 seconds. I had 5 long contracts which were filled in first two and three seconds. Four contracts either reached their target or were stopped out at BE. The last contract did not stop out at BE as the OCO order was set up. Long story short the last contract stop somehow was rejected because it ended up above the current price and continued for 13 points down before I noticed it because there was not stop left since it was rejected. So I took a loss on that contract which was intended to BE when the price reversed down. From the description of this function, will this solve the issue I had this morning and create a new stop order to chase the price down so I do not end up with an uncovered short position ie no stop. And will this work with Teton? |
| [2022-12-02 22:59:21] |
| Sierra_Chart Engineering - Posts: 25422 |
Yes this will solve the problem. Here is the documentation: Global Trade Settings Windows: Auto-Send Market Order On Rejected Stop Attached Order (Global Settings >> General Trade Settings >> General) It sends a market order to exit the position immediately. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-02 23:00:10
