Date/Time: Fri, 13 Nov 2026 21:24:37 +0000
sharing sierra4.config (again)
View Count: 907
[2022-12-01 18:55:18]
User1293821 - Posts: 42
The other post is now locked, but today I had the chance to update to 2457. Sierra4.config is still showing my account number as well as my email / phone number (for alerts) in plain text. The email and phone number go away if I remove them from General > Alert Settings Tab > Notification.
I've closed and restarted sierra a number of times and used saved all, but my account number continues to be available in plain text.
[2022-12-01 19:05:11]
I was able to login or connect using a sub-instance and that one does not contain my account number.
[2022-12-01 20:30:24]
How are you determining this?:
Yes this is true:
[2022-12-01 20:40:04]
1. Open sierrachart
2. Connect to data feed
3. Save All & Exit
4. Open Sierra4.config in notepad
5. ctrl + f to search
6. search for my account number
I've repeated those steps 3-4 times now and everytime in my main instance the account number is visible. My sub-instances have updated and the account number does not appear when I search for it.
[2022-12-01 20:44:53]
This could be from the Trade Activity Log. If you go to the Trade >> Trade Activity Log is your account number selected on that window?
[2022-12-01 20:47:04]
That was it. Awesome thanks a lot!
[2022-12-01 20:54:45]
Ok we will fix this going forward.
