Date/Time: Fri, 13 Nov 2026 21:24:57 +0000
30 YEAR US BOND CHARTS
View Count: 1302
| [2022-12-01 15:36:20] |
| User410836 - Posts: 18 |
Hi, I am not getting 30 yr us bond data and charts correctly. My other charts for ES and Crude charts are coming up perfectly fine. I have attached the image for the charts; also I am a Tradestation chart for the US 30 yr bond chart for your kind comparison to see the problem. Please advise how to correct the problem. Thanks....regards......Mickey |
| Private File |
| [2022-12-01 18:29:34] |
| John - SC Support - Posts: 48527 |
We do not know where the chart that you are showing from another system is from, but just to verify what we are seeing we looked at the CME Group chart and the attached is what the CME Group shows for a chart for the Micro 30 Year Treasury Bonds, which matches the data in your Sierra Chart.
| [2022-12-01 19:05:31] |
Hi, Thank you so much for your kind reply. The chart and the data which is attached is for 30 yr us treasury bonds and not the micro yield chart which you attached. The other chart I attached is from tradestation charting which I also use. And IF I may request you to kindly look at the 30yr us bond chart(dec.22 front month) then you would see that my chart data is not coming correctly. Thank you so much again....Regards....Mickey |
| [2022-12-01 20:16:25] |
| Sierra_Chart Engineering - Posts: 25422 |
Bond futures are deliverable, so December is no longer active. You have to go on to March 2023 at this time: Changing to a New Futures Contract Month Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-12-01 22:28:11] |
The product you are referencing is named "U.S. TREASURY BOND FUTURES" at the CME Group. As noted above, the currently traded contract is the March contract and this is the reason why your chart is so spartan - because the December contract is not being traded much. Attached are the chart images from the CME Group for the two contracts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
