Date/Time: Fri, 13 Nov 2026 21:36:23 +0000
Volume by Price Bid x Ask Values overlap TPO profile letter at early stage of the profile
View Count: 638
| [2022-11-23 21:16:57] |
| ticinotrader - Posts: 431 |
Dear Support, May I ask for your advice in the following topic: When I create a TPO Profile chart with a Volume by Price study added that displays the Bid x Ask volume in each bars, if I right align the Volume Profile, the numbers overlap the TPO profile during the earlier part of the developing TPO profile. Please see the two attached screenshots for an example. Later, when the profile is nearly completed, this is not an issue, but it exists when the profile is in its early stage. The volume bars do not overlap the TPO letters - only the volume numbers. I know, that by increasing the bar spacing of the chart, the overlap issue can be fixed, but it results in too wide TPO profiles. Is there any way to adjust the spacing between TPO letters and the vol profile numbers that is maintained automatically? If not, can you please add this feature to the study that maintains proper distance/spacing between the vol profile numbers and the TPO letters? Thanks in advance for the reply. Date Time Of Last Edit: 2022-11-23 21:19:02
| [2022-11-23 21:28:14] |
| John - SC Support - Posts: 48527 |
This would be something we would need to add. We would have to check if the text is larger than the bars and then adjust the spacing based on the text size. As with all these kind of requests, we can not say when we would be able to get to it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
