Date/Time: Fri, 13 Nov 2026 21:36:24 +0000
Extend Previous Weekly OHLC
View Count: 748
| [2022-11-23 04:05:21] |
| adenfx - Posts: 1 |
Hello ! I'm currently struggling extending Previous Weekly OHLC to the right with the study "Previous/Period OHLC-Variable Period", it extends the current week OHCL but I'm looking to extend the previous one instead Kind regards |
| [2022-11-23 15:04:30] |
| John - SC Support - Posts: 48527 |
We are not fully understanding the situation, as the Period OHLC - Variable Period allows you to shift the week you are looking at on the current time frame from either the current one or the previous period. You do this using the Input for Use Current Period. When set to No you will see the previous periods OHLC on the current period (all periods are shifted forward by 1). So if you want to see the previous period on the current period, then use this option. If you want to keep the current period and then see the previous period on the current one, then use a second copy of the Period OHLC - Variable Period and set the option for Use Current Period to No, so then you will have the previous and current periods at the same time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
