Date/Time: Fri, 13 Nov 2026 21:36:33 +0000
MES/ CQG
View Count: 760
[2022-11-22 16:25:52]
User310045 - Posts: 1
Hi!
I'm back on sierra after some months off, and i swith from the ES to the MES.
But it looks like that I can't use CQG to trade the MES and need to change from AMP to stage5, edge clear or some of the broker that accepte to use Teton is that right ?
Change is a cost (at least 30$ to withdraw money from AMP) and since i just renewed I'm a bit stuck.
Question: Is there any way I can keep my set up (AMP/CQG) and trade the MES ?
If not, may you offer me a discount to cover my cost ?
Thanks for you help
[2022-11-22 18:18:08]
We are not aware of any reason you would need to change brokers. You should be able to trade the MES with AMP by using CQG for your order routing.
Two things we want to point out:
1) Our servers are showing that your "Global Settings >> Data/Trade Service Settings >> Current Selected Service[/b] is set to SC Data - All Services. In order to place a trade, you need to be connected to your CQG account. Refer to the Setup Instructions for CQG at the following link:
CQG Trading Platform Service: Setup Instructions
2) You can not get the data for the CME Group and EUREX from CQG into Sierra Chart. You will need to use our Denali Exchange Data Feed for this data. We see that you have used the Denali Exchange Data Feed in the past, so you only need to activate the exchange(s) for the CME Group for which you want the real-time data. You can activate the exchange(s) here:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
