Date/Time: Fri, 13 Nov 2026 21:24:41 +0000
Compare Today ID.# with previous ID.#
View Count: 748
| [2022-11-22 12:33:02] |
| User134797 - Posts: 56 |
Hi everyone, I like to compare some data form today ID.# with the previous ID.#. I know you have to work with [-1], but I get an erro. I Like to use this in Marktprofile. Can someone help me with this. Best, Iwan |
| [2022-11-22 17:17:11] |
| John - SC Support - Posts: 48527 |
There is no data within the TPO that is available from the Subgraphs. The subgraphs that are present are there just to define the colors of the various items. What information are you wanting to access? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-23 08:19:43] |
Hi John, I like to compare the today open with the previous ID.#(SG16) for example Or Today ID.#(SG18) with previous ID.#(SG16) for example. Best Iwan |
| [2022-11-23 15:20:43] |
Subgraph 16 for the TPO is the Value Area Extension Lines and Subgraph 18 is the Open Marker. Again, these subgraphs do not hold the actual data for these items, they are just used to set the colors. We understand that you want to compare the Open with something, but are you wanting to check it against the Value Area lines? If so, which one, the high or low (or somehow both). Just give us the information of what you want to accomplish (without using subgraph references, just use words, and do not reference studies - just tell us what you want) and we can then tell you how to get there. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-24 09:05:10] |
Morning, 1) I like to compare today the Open Marker for the TPO with the Previous Value Area Extension Line High of the TPO. 2) I like to compare today the Open Marker for the TPO with the Previous Value Area Extension Line Low of the TPO. 3) I like to compare today the Open Marker for the TPO with the Previous High of the distribution. 4) I like to compare today the Open Marker for the TPO with the Previous Low of the distribution. Best, Iwan |
| [2022-11-28 14:53:16] |
What do you want to do with these comparisons? Are you wanting an Alert, or do you want to see the information plotted as a line (or some other data point style)? In general, you will need to do the work to get this information from a chart that does NOT have the TPO on it. You will want to set the chart to have the same Session Times as the TPO chart along with ensuring that the Evening Session is set in the same way as the TPO (if you are not viewing the Evening Session in the TPO, then this chart should not be using the Evening Session, and vice versa). Then use the Daily OHLC study to get the Open/High/Low information for today and the previous day (you will want to use 2 copies of this study to get today's data and the previous day's data) and use the TPO Value Area Lines study to get the Value Area line data. Refer to the following: Daily OHLC TPO Value Area Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
