Date/Time: Fri, 13 Nov 2026 21:36:21 +0000
CQG
View Count: 711
| [2022-11-21 03:17:56] |
| User149697 - Posts: 2 |
Its been a while since i have traded, do you still work with CQG and if so, what pkg do i need. Thank you |
| [2022-11-21 16:19:06] |
| Sierra_Chart Engineering - Posts: 25422 |
Yes CQG is supported. Refer to: CQG Trading Platform Service But we do recommend using Teton order routing when trading CME Group markets: Sierra Chart Teton Futures Order Routing In either case you would need service package 10 or higher. We have reactivated your account for a week now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-21 16:19:35
