Date/Time: Fri, 13 Nov 2026 21:11:14 +0000
[Programming Help] - ASCIL How to determine when/if an Attached Order has been moved to Breakeven ...
View Count: 824
[2022-11-20 11:43:10]
User92573 - Posts: 622
Dear Support
I've not been able to find an example, or documentation, to explain how I can determine when an attached stoploss order moves to breakeven.
I can obviously use <= or >= a trigger value but I could not find another more appropriate method that traps the actual Order event.
The goal is to simply send a message to the log stating a move to Breakeven has occurred and at what price?
I currently save the following to PerVars for my other studies which do not use attached orders.
NewOrder.Target1InternalOrderID;
NewOrder.Stop1InternalOrderID;
NewOrder.InternalOrderID;
But with attached orders I'm a little stuck. Any short example, or direction greatly appreciated.
Many thanks.
[2022-11-29 10:36:46]
ForgivingComputers.com - Posts: 1253
If you are keeping track of the order IDs for the stops, then you can look up the current Price like this:
s_SCTradeOrder TradeOrder;
sc.GetOrderByOrderID(OrderID, TradeOrder);
double Stop = TradeOrder.Price1;
[code]
[2022-12-01 19:27:44]
Yes, I track all Order ID's but other than testing the Stop price against the Trade Order Price, or the current Stop against the Stoploss, I could not identify a specific Breakeven, or trigger flag. I suppose these solutions are adequate, but I felt there would be a flag of sorts.
Thank you for replying.
[2022-12-01 19:40:58]
Not sure what kind of flag you are looking for, as I don't know how you would see the flag without an if statement or equivalent. You can also check the result of the sc.ModifyOrder() to know if it succeeded, assuming your study initiated the move to BE.
Date Time Of Last Edit: 2022-12-01 19:41:45
[2022-12-04 12:20:05]
It wasn't so much me creating a flag on a change of values. I thought there might be a specific event that Sierra tracked but the test using ID's and creating my own event flag is clearly a solution.
Thank you for reply.
Date Time Of Last Edit: 2022-12-04 12:21:02
