Date/Time: Fri, 13 Nov 2026 21:50:54 +0000
Service package does not support this function
View Count: 699
| [2022-11-13 22:55:36] |
| CAACAP - Posts: 51 |
I have 7 days to expiration i see that the package that i need is now 10 would i be able to get an extension to my original expiration or a credit toward the new package? Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2022-11-13 17:45:39.592 * |
| [2022-11-13 23:02:47] |
| Sierra_Chart Engineering - Posts: 25422 |
This is resolved for your account. You will now be able to connect.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-13 23:03:25
