Date/Time: Fri, 13 Nov 2026 21:50:25 +0000
Numbers bar profile POC
View Count: 705
[2022-11-13 22:06:43]
User484554 - Posts: 3
Hello, I was wondering if anyone can help. I cannot work out how to scale down th POC highlight on my number bar profile so it is sized tobe the same as the profile bar. Thank you
imageCapture.PNG / V - Attached On 2022-11-13 22:02:41 UTC - Size: 32.43 KB - 274 views
[2022-11-14 11:11:56]
ticinotrader - Posts: 431
This is a chartbook that was originally created by me (ticinotrader).
If you are a member of my site and need support, you can message me directly there using the contact form to ask for assistance.
Regards,
tt
