Date/Time: Fri, 13 Nov 2026 21:50:26 +0000
Optimizing Hardware and Software for Stability and Performance in SC
View Count: 773
| [2022-11-12 21:54:29] |
| User379468 - Posts: 508 |
What is the most stable and fastest OS and version and currently to operate SC on? Any recommendations to configure it to optimize for trading purposes? What is the recommended networking router/specifications to optimize latency, stability, and speed for SC, for multiple trading machines connecting through it? Is there a recommended router packets per second spec? Is there a dual WAN/failover/load balancing router that is recommended? How can one choose/optimize which SC Denali Feed servers one is connecting to based on their location? Date Time Of Last Edit: 2022-11-12 22:00:45
| [2022-11-13 14:12:52] |
| Sierra_Chart Engineering - Posts: 25422 |
For the operating system we like Windows 7 but of course this is really quite out of date. We certainly would not recommend Windows 11. There is nothing special to do for configuration of the Windows operating system for Sierra Chart. As far as packets per second, we would allocate 500 packets per second per computer. So router needs to be able to handle at least that. Is there a dual WAN/failover/load balancing router that is recommended? This is not relevant. You are going to be connected to one location and that is Chicago for CME data: How can one choose/optimize which SC Denali Feed servers one is connecting to based on their location? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
