Date/Time: Fri, 13 Nov 2026 21:50:25 +0000
large number gillion suffix have 3 decimal 12.123G insteand of 2 decimal 12.12G
View Count: 911
| [2022-11-12 21:14:18] |
| User686802 - Posts: 69 |
Large number gillion suffix have 3 decimal 12.123G instead of 2 decimal 12.12G. Where do I change the default large number prefix to 2 digits, it works correctly with millions 12.12M but when charting bitcoin volume into gillions, it some show shows 3 decimal places like 12.123G , see photo. I think you can see visually a standard 2 digits with large number suffix for all million, gillion, trillion is a sensible approach.
| [2022-11-14 16:44:28] |
| John - SC Support - Posts: 48527 |
The system is setup to give 3 significant digits when the value is 1 Billion or higher. There is not a way to change this.
