Date/Time: Fri, 13 Nov 2026 21:50:43 +0000
Question on: "Send Attach order by Position"
View Count: 867
[2022-11-11 18:18:04]
User396 - Posts: 61
I do not see "Send Attach order by Position" option in second instance but I can see for the main or first instance. Is this by design? Or am I doing something wrong?
thank you
[2022-11-11 19:34:39]
Where exactly are you looking for this option? It sounds like you may have added it to the Chart Shortcut menu (right-click menu) in which case you would need to do the same thing in the Sub-Instance.
It should definitely be on the Trade Window pulldown for the various order types.
[2022-11-11 20:17:48]
User396 - Posts: 61
yes, I use it with right click menu but on the second instance it is not available as right click option. Hence I ask for your help.
[2022-11-11 21:02:53]
You need to add it to the right-click menu in that second instance. You can add it by selecting Global Settings >> Customize Chart Trade Menu.
[2022-11-11 21:52:06]
User396 - Posts: 61
solved this problem!
why all these buttons "Buy MKT", "Sell MKT".... are grayed out? how do I enable them?
thank you
[2022-11-11 22:04:08]
We assume you are referring to the buttons on the Trade Window. In which case, refer to the following documentation:
Global Trade Settings Windows: Display Trade Window Controls (Global Settings >> Chart Trade Settings >> General)
