Date/Time: Fri, 13 Nov 2026 21:50:40 +0000
Confused about Forex feeds
View Count: 812
| [2022-11-11 14:19:15] |
| User871035 - Posts: 2 |
Hi, I hope you're dong well. I've tried to look all over the support boards and I can't seem to find the correct. Please let me know the difference between FXCM - Forex and Cash/Spot Forex data feed on, if there is any? It doesn't outline the key differences. I am, for the most part, a forex trader. Sierra Chart Exchange Data Feed < This is the package in question, right at the bottom of the page; FOREX/Spot cash, listed as $21USD a month. Would this also be added additionally to my current package of $36 a month? Please let me know as soon as possible, thank you. |
| [2022-11-11 15:31:03] |
| Sierra_Chart Engineering - Posts: 25422 |
You definitely do not want to pay extra for the Forex data from the Sierra Chart Exchange Data Feed. You just want to use this data: Sierra Chart Real Time and Historical Forex and CFD Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
