Date/Time: Fri, 13 Nov 2026 21:50:45 +0000
Daily, weekly separator
View Count: 1531
| [2022-11-11 13:37:58] |
| User266447 - Posts: 280 |
Is there a separator that I can put on a chart that shows: a) when does a day start and end? Similar to weeks? b) Another one showing a daily high and low? |
| [2022-11-11 18:51:39] |
| John - SC Support - Posts: 48527 |
a) The Vertical Grid can do this. Refer to the following: Chart Settings: Show Vertical Grid (Chart >> Chart Settings >> Grid >> Show Vertical Grid menu) b) Refer to the following: Daily OHLC If you just want High and Low you would set the Subgraphs for Open and Close to Ignore. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
