Date/Time: Fri, 13 Nov 2026 21:50:45 +0000
encrypted containers
View Count: 728
| [2022-11-11 02:02:27] |
| User486817 - Posts: 83 |
hello, is it possible to use SC from inside an encrypted container? currently i run SC from the Sierra Chart folder like normal but i now desire increased security for my files. is it possible to place that SC folder into a container and run SC out of the container? i prefer to use veracrypt and am just wondering if SC will work normally if i do this. is it a normal drag and drop affair? can i update directly within the container? kindest regards, |
| [2022-11-11 10:42:54] |
| Sierra_Chart Engineering - Posts: 25422 |
We do not see any problem with this. Should be just fine.
