Date/Time: Fri, 13 Nov 2026 21:56:47 +0000
Why there is no data after a new computer.
View Count: 694
| [2022-11-09 07:18:40] |
| rui - Posts: 1 |
After I changed a computer, I could not normally use SC. I could only log in and not see the data. After the data code was renovated, I could not see the market chart data.
| Attachment Deleted. |
| [2022-11-09 13:38:46] |
| Sierra_Chart Engineering - Posts: 25422 |
You may not have the correct Trading Service selected or you may not using the correct symbols. Refer to: Data/Trading Service Connection and Symbol Issues: 1.3. Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
