Date/Time: Fri, 13 Nov 2026 21:56:31 +0000
Which files do I need to copy to new instance if I want to have all of my settings?
View Count: 623
| [2022-11-09 01:24:49] |
| User396 - Posts: 61 |
I just installed another instance of Sierra Chart. Which files do contain all the settings and customization? Thank you |
| [2022-11-09 12:21:05] |
| Sierra_Chart Engineering - Posts: 25422 |
All of this is documented here: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
