Date/Time: Fri, 13 Nov 2026 21:56:31 +0000
Connection problem
View Count: 642
| [2022-11-08 18:51:06] |
| User890357 - Posts: 1 |
I am not getting connected on Sierra Chart. The last time I was connected was on 11/4. AMP has reactivated my CQG
| [2022-11-08 22:20:35] |
| John - SC Support - Posts: 48527 |
If you are having problems connecting to CQG, then go through the Setup Instructions for CQG at the following link: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
