Date/Time: Fri, 13 Nov 2026 21:56:35 +0000
After Switch to Rithmic how it works with SC historical data?
View Count: 1022
| [2022-11-08 18:45:28] |
| Stephan_CH - Posts: 18 |
Hi Today I have switched to Rithmic market data, login works and data feed established. I have read that download of historical data is prohibited by Rithmic policy, history data will come from Sierrachart. In your documentation (Rithmic Trading Platform Service) I have read, that historical Intraday and Daily data comes from SC Data Service. Question: How can I configure Rithmic as real time market data feed a SC Data for intraday and daily historical data at the same time? Sorry, I doesn't find a how to in documentation. Thanks for your support. |
| [2022-11-08 22:18:45] |
| John - SC Support - Posts: 48527 |
Our documentation does not state that historical Intraday data will come from Sierra Chart. Rather, it states the opposite - that historical intraday data is not included. It does state that historical daily data is included and comes from us. Regardless of the specifics of the documentation - what we state above is correct. There is not a way to get our historical intraday data with Rithmic. Therefore, we recommend you use our Denali Exchange Data Feed instead. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-09 13:39:37] |
Implies last sentence "..we recommend you use our Denali Exchange Data Feed instead" to: 1. Subscribe Sierra Chart real time data 2. Configure Rithmic Data/Trade Service settings with login data at "Trading" and "Market Data" fields without any logon data at "Historical Data" fields 3. Set "Allow Support for Sierra Chart Data Feeds"=YES Is this the configuration to establish order routing and market data with Rithmic and get Intraday and Daily Data from Sierra Chart? |
| [2022-11-09 13:45:32] |
| Sierra_Chart Engineering - Posts: 25422 |
Not exactly. What you want to do is not supported. 1. You do have to pay the CME exchange fee for real-time data. And then both the real-time and historical data will come from Sierra Chart. 3. Yes this is correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-09 13:56:04] |
OK, this means for point 2. Configure Rithmic Data/Trade Service settings with login data at "Trading" field only (for order routing) leaving "Market Data" and "Historical Data" fiels blank; all data will be delivered by Sierra Chart, isn't it? (sorry for repeating, english is not my mother tongue and technical configuration really complicated for me) |
| [2022-11-09 14:00:20] |
Yes this is correct: OK, this means for point 2. Configure Rithmic Data/Trade Service settings with login data at "Trading" field only (for order routing) leaving "Market Data" and "Historical Data" fiels blank; all data will be delivered by Sierra Chart, isn't it? Although how you have those Market Data and Historical Data Username/Password fields set is not really relevant.
