Date/Time: Fri, 13 Nov 2026 21:56:54 +0000
5y Composite profile
View Count: 674
| [2022-11-08 18:43:55] |
| User565063 - Posts: 7 |
Hi all, I would like to build a 5y composite volume profile for ES. The way i'm doing it now is to open an intraday ES chart go to chart setting>data limiting>days to load for intraday chart data type= 1750. This is obviously very slow and data heavy. Is there a better way of achieving the same thing? Thanks |
| [2022-11-08 22:14:37] |
| John - SC Support - Posts: 48527 |
It depends on how accurate you want the data. You can use a daily (historical) chart, which would be much faster, but the data will be more granular, but given the timeframe, it will probably be good enough for what you are wanting. Refer to the information here: Volume By Price Study: How Volume by Price is Calculated for Historical Daily and Higher Timeframe Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
