Date/Time: Fri, 13 Nov 2026 21:56:53 +0000
Pulling/Stacking column bars
View Count: 1192
[2022-11-08 17:13:36]
rondawes - Posts: 54
I have a DOM with a Combined Bid/Ask Market Depth Pulling/Stacking column. I have the Volume Bars enabled. It appears that the bar lengths are in proportion to the length of the biggest one that's displayed in either the bid or ask side. So if the largest one is 200, then one that is 100 is half the length of the 200 level. But if the largest one is 100 then one that is 50 appears as half length. Because the lengths fluctuate greatly depending on the length of the biggest level it does not give a proper feel for the activity without reading the actual numbers which is hard on an active instrument. Is there a way that the max bar length can be set to a user specified number? Then all levels would be proportional to that fixed max length. For me this would be a great improvement. If there is a way to do this now, please let me know. Thanks.
[2022-11-08 22:03:40]
There is not a way to do what you are wanting. The bar length is always relative to the largest value at that time.
[2022-11-08 22:16:09]
John, yes, I understand that. But would you consider adding it as a new feature?
[2022-11-08 23:15:52]
We have set this as a Feature Request, although we do keep track of all requests any time there is something we do not have.
Just keep in mind that we can not say when, or if, we will get to any particular request.
