Date/Time: Fri, 13 Nov 2026 21:56:39 +0000
major problems with execution
View Count: 768
| [2022-11-08 16:27:13] |
| Shlomi.B - Posts: 50 |
Hi, im having some major issues executing orders, im getting error messages and when i get filled on limit orders its fills me at a different price point. also when I place a limit order and not get a fill the P&L is showing like I am in a trade but I am not and then when I try to flatten this phantom position its drawing me into a loss. whats is going on with my platform? I contacted my broker and they said that this is a problem with the platform. this issue just cost me $350 please help my system is buggy |
| [2022-11-08 16:38:40] |
this issue only seems to happen when I am executing more then 1 contract
| [2022-11-08 17:08:37] |
the system is executing different levels that I intend, the system is not respecting brackets as well
| [2022-11-08 22:02:34] |
| John - SC Support - Posts: 48527 |
The reason you are having issues is that you do not have any exchanges active, so you are not viewing the Real-time data. You can activate the exchange(s) you need for the CME Group data at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
