Date/Time: Fri, 13 Nov 2026 21:56:38 +0000
Horizontal line for cryptochart doesn't work properly with volume study
View Count: 751
| [2022-11-08 13:08:43] |
| User361939 - Posts: 170 |
1. Open chart for ETHUSD_PERP_BINANCE 2. Add Volume study 3. Draw horizontal line 4. In properties i put value and its different on chart. Screen at the attachment. |
| [2022-11-08 13:35:34] |
| User431178 - Posts: 910 |
Floating Point Value Error - ACSIL Programming Concepts: Floating Point Value Error
| [2022-11-08 18:40:58] |
| John - SC Support - Posts: 48527 |
You really need to adjust the overall volumes from the data using the Volume Multiplier, as the values are too large to be handled properly. Refer to the information here: Chart Settings: Volume and Open Interest Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
