Date/Time: Fri, 13 Nov 2026 21:56:53 +0000
Cannot open specific Volume chart for Crypto
View Count: 602
| [2022-11-08 13:01:53] |
| User361939 - Posts: 170 |
I found interesting "bug" for cryptocharts. When i put volume Value for chart type Volume chart: 350000000 it will be converted into: 2147483647 Sierra Ver. 2430 i did that on chart: ETHUSD_PERP_BINANCE |
| [2022-11-08 18:39:19] |
| John - SC Support - Posts: 48527 |
The volume is too large for Sierra Chart to handle. You would need to use a Volume Multiplier to reduce the size of the volume so that it can be handled within the software. Refer to the following: Chart Settings: Volume and Open Interest Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
