Date/Time: Fri, 13 Nov 2026 21:56:48 +0000
[Programming Help] - Ordering of highlight drawings, Studies and Main Graph
View Count: 646
[2022-11-08 12:14:08]
Stephanie G Kessel - Posts: 2
I am using a vwap band study. My highlighting rectangles and lines are hidden beneath it unless I choose "Draw Highlight Drawings Underneath Main Graph and Studies. The problem I am having with this is that the main graph is then not as prominent, as it is also below the rectangles making them less opaque.
I would like for the main graph to be at the top in terms of layer order, then the highlighting rectangles below that, then the vwap study at the bottom. Is there a way to separate studies and main graph in terms of how they are handled in layer ordering? Or, is there another work around?
Thank you!
[2022-11-08 18:32:23]
There is not another option to do what you want. As you have already found, there are the options are to move the drawings to the top or the bottom of the ordering. There is not a way to separate this from the Main Price Graph and the studies, which are displayed in order with the Main Price Graph on top and then the studies drawn on top of each other as you go down the list (so the study at the bottom of the list is drawn closest to the top).
There is one other option to display a study on top of the Main Price Graph on each study, but again, not one that will separate where the drawings are in relation to these.
Date Time Of Last Edit: 2022-11-08 18:35:57
