Date/Time: Fri, 13 Nov 2026 21:56:42 +0000
Historical Data doesn't download for the current day
View Count: 663
[2022-11-07 16:19:51]
User535952 - Posts: 3
I can't receive the Historical data, it's keeping Downloading all day but I can see on my chart's only yesterday data.
The price is moving but the charts doesn't downloaded. all the time was everything ok, it happen on last Friday. The historical data doesn't dowload just for the current day, no bars or candles just the price is moving.
Print screen attached
Please check, thank's
Giedrius
imageScreenshot (24).png / V - Attached On 2022-11-07 16:17:12 UTC - Size: 1.24 MB - 223 views
[2022-11-07 19:15:34]
You are using Rithmic. Refer to:
Rithmic Trading Platform Service: Rithmic Support Policy
[2022-11-07 20:20:05]
Any data doesn't load even Sierra Charts, take a look at print screen.
imageScreenshot (28).png / V - Attached On 2022-11-07 20:19:38 UTC - Size: 392.12 KB - 230 views
[2022-11-08 15:59:23]
When you change your Service to SC Data - All Services and you want to fill in missing historical data, then you will need to select Edit >> Delete All Data and Download.
Note that you only need to do this once per symbol and not for every chart.
