Date/Time: Fri, 13 Nov 2026 21:56:55 +0000
color backup after green candle
View Count: 721
| [2022-11-07 06:45:52] |
| User811622 - Posts: 38 |
Need help with alert formula. I would like to get background color plotted on 4th candle. That is after 3 x red candles down, then on 4th candle, it turn green. Formula below doesn't seem to work. =AND((C[-1]<O[-1],C[-2]<O[-2],C[-3]<O[-3]),(C>O)) Thanks so much! |
| [2022-11-07 22:55:28] |
| John - SC Support - Posts: 48527 |
You have an extra parentheses that is causing an issue. Your formula should be the following: =AND(C[-1]<O[-1],C[-2]<O[-2],C[-3]<O[-3],C>O) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
