Date/Time: Fri, 13 Nov 2026 21:56:48 +0000
[User Discussion] - question about cumulative bars trade and cumulative un down tick
View Count: 709
[2022-11-07 06:33:53]
User728971 - Posts: 3
As you can see in the images there is a big diference between cumulative bars trade and cumulative up down tick a 2K diference of delta.My question is went I should use one or another, because if you trust in the cumulative up down you has been un error----there is a nice gap
https://www.sierrachart.com/image.php?Image=1667802114446.png
https://www.sierrachart.com/image.php?Image=16678026021.png
Thx for your time
[2022-11-07 22:52:50]
Refer to the information for each of these studies and what they represent at the following links:
Cumulative Delta Bars - Up/Down Tick Volume
Ask/Bid Volume Difference Bars
