Date/Time: Fri, 13 Nov 2026 21:56:52 +0000
Sierra Charting Platform Will Not Open
View Count: 641
| [2022-11-07 01:26:34] |
| User386902 - Posts: 7 |
Same problem experienced as last Sunday Evening. I log in through my Transact Account - quote board opens. Charting platform does not. I have updated my user information as requested. Please advise. Thanks. Ray Burchett
| [2022-11-07 08:21:22] |
| Sierra_Chart Engineering - Posts: 25422 |
Go into this folder on your system: C:\SierraChart\SierraChartTransActMA\ Run the SierraChart_64.exe file. And refer to: Software Download: Setting up Shortcut to Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-07 08:21:58
