Date/Time: Fri, 13 Nov 2026 21:56:48 +0000
[Programming Help] - Programming Help ACSIL
View Count: 3095
[2022-11-07 00:36:46]
User183724 - Posts: 194
working though the ACSIL examples on SC website
Using Drawing Tools From an Advanced Custom Study
// Marker example
copied and pasted to NPP ... added #include "sierrachart.h" ... added SCDLLName("Marker example")
I received a list of errors when i attempted to Remote Build.
thanks
code starts below
// Name of the custom study.
// Marker example
s_UseTool Tool;
int UniqueLineNumber = 74191;//any random number.
Tool.Clear(); // Reset tool structure. Good practice but unnecessary in this case.
Tool.ChartNumber = sc.ChartNumber;
Tool.DrawingType = DRAWING_MARKER;
Tool.LineNumber = UniqueLineNumber +1;
BarIndex = max(0, sc.ArraySize - 35);
Tool.BeginDateTime = sc.BaseDateTimeIn[BarIndex];
Tool.BeginValue = sc.High[BarIndex];
Tool.Color = RGB(0,200,200);
Tool.AddMethod = UTAM_ADD_OR_ADJUST;
Tool.MarkerType = MARKER_X;
Tool.MarkerSize = 8;
Tool.LineWidth = 5;
sc.UseTool(Tool);
compiler errors start below
-- Starting remote build of Custom Studies Source files: Markerexample.cpp. 64-bit -- 18:21:30
Allow time for the server to compile the files and build the DLL.
The remote build did not succeed. Result:
Markerexample.cpp:10:1: error: 'Tool' does not name a type
10 | Tool.Clear(); // Reset tool structure. Good practice but unnecessary in this case.
Markerexample.cpp:11:1: error: 'Tool' does not name a type
11 | Tool.ChartNumber = sc.ChartNumber;
Markerexample.cpp:13:1: error: 'Tool' does not name a type
13 | Tool.DrawingType = DRAWING_MARKER;
Markerexample.cpp:14:1: error: 'Tool' does not name a type
14 | Tool.LineNumber = UniqueLineNumber +1;
Markerexample.cpp:16:1: error: 'BarIndex' does not name a type
16 | BarIndex = max(0, sc.ArraySize - 35);
Markerexample.cpp:18:1: error: 'Tool' does not name a type
18 | Tool.BeginDateTime = sc.BaseDateTimeIn[BarIndex];
Markerexample.cpp:19:1: error: 'Tool' does not name a type
19 | Tool.BeginValue = sc.High[BarIndex];
Markerexample.cpp:21:1: error: 'Tool' does not name a type
21 | Tool.Color = RGB(0,200,200);
Markerexample.cpp:22:1: error: 'Tool' does not name a type
22 | Tool.AddMethod = UTAM_ADD_OR_ADJUST;
Markerexample.cpp:24:1: error: 'Tool' does not name a type
24 | Tool.MarkerType = MARKER_X;
Markerexample.cpp:25:1: error: 'Tool' does not name a type
25 | Tool.MarkerSize = 8;
Markerexample.cpp:27:1: error: 'Tool' does not name a type
27 | Tool.LineWidth = 5;
Markerexample.cpp:29:1: error: 'sc' does not name a type; did you mean 's_sc'?
29 | sc.UseTool(Tool);
| s_sc
-- End of Build -- 18:21:36
[2022-11-07 02:34:07]
i figured out part of my error... i simply copied the code and didn't make a study out of it. I re wrote the study including some of what is required to make it work.
code starts below
SCDLLName("Markerexample")
SCSFExport scsf_Markerexample(SCStudyInterfaceRef sc)
  if (sc.SetDefaults)
    sc.GraphName = "Function";
    sc.AutoLoop = 1; // Automatic looping is enabled.
    return;
// Marker example
s_UseTool Tool;
Tool.LineWidth = 5;
s_sc.UseTool(Tool);
error starts here
-- Starting remote build of Custom Studies Source files: Markerexample.cpp. 64-bit -- 20:29:02
Markerexample.cpp: In function 'void scsf_Markerexample(SCStudyInterfaceRef)':
Markerexample.cpp:31:1: error: 'BarIndex' was not declared in this scope
31 | BarIndex = max(0, sc.ArraySize - 35);
Markerexample.cpp:44:5: error: expected unqualified-id before '.' token
44 | s_sc.UseTool(Tool);
-- End of Build -- 20:29:08
still cant make it work but am closer
[2022-11-07 04:04:54]
i declared BarIndex as int BarIndex (0)
so I'm down to
Markerexample.cpp:49:5: error: expected unqualified-id before '.' token
49 | s_sc.UseTool(Tool);
-- End of Build -- 22:03:31
I don't know what this is or how to fix it.
[2022-11-07 08:25:56]
User431178 - Posts: 910
Change
s_sc.UseTool(Tool);
to
sc.UseTool(Tool);
That is all.
s_sc is the type of struct, your function needs to use 'sc', which is a reference passed into the function by SCStudyInterfaceRef sc.
SCStudyInterfaceRef is typedef alias for s_sc&, and sc is the variable name.
[2022-11-07 17:11:02]
thank you... that worked. the example on the site shows that with the s_sc.Usetool(tool) so I just copied it that way. I got a ways to go yet on understanding all the syntax and what all the functions do. Some of the examples ive found are older and I'm guessing theres been some changes made. anyway thanks again
[2022-11-07 17:39:00]
I just looked at the site again and i copied it wrong. the site doesnt have the s_ . something to watch for next time
