Date/Time: Fri, 13 Nov 2026 21:56:50 +0000
VBP Total volume - keep each week on chart and not just current week?
View Count: 777
| [2022-11-06 23:31:17] |
| HeyUgly - Posts: 288 |
hello Pic attached. I have a daily candlestick chart set to weekly I have my Volume profile set to weekly using VBP study, works great I want to know if its possible to have weely Volume thats circled in the pic, stay in each previous week? so even when the week closes, i can look back at the previous weeks and see their volumes as well? |
| [2022-11-07 22:42:40] |
| John - SC Support - Posts: 48527 |
The only way to do this would be to stack the weekly profiles on the far right, as you can not have multiple profiles within a time period, but you can on the right. Then use the Number of Periods Back to Reference to reference back however many weeks you want. Refer to the following: Volume By Price Study: Number Of Periods Back To Reference You would have to add multiple Volume by Price studies - one for each week and set each to align to the far right. Refer to the following: Volume By Price Study: Right Aligning Multiple Profiles For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
