Date/Time: Fri, 13 Nov 2026 21:56:52 +0000
trading data issue
View Count: 635
| [2022-11-06 23:18:24] |
| User985241 - Posts: 1 |
I'll first admit i'm new and most likely not doing it right. I"m running sierra chart. Purchased CQG data through AMP. Changed the data/trade services to CQG webAPI and entered correct login/password. Sierra Chart shows green connected but I'm not getting any charts or dom info for F.US.EPZ22. Not sure what to do.
| [2022-11-07 00:51:18] |
| Sierra_Chart Engineering - Posts: 25422 |
Complete the exchange agreements: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements And then you need to activate the exchanges you need here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
