Date/Time: Fri, 13 Nov 2026 21:56:33 +0000
Market Profile
View Count: 1059
[2022-11-05 17:08:28]
User591166 - Posts: 9
bonjour
sur un chart market profile, la modification du parametre ln:123 ne fonctionne pas :
closing range time length in minutes = 5 par defaut.
cordialement
[2022-11-07 22:06:26]
From Google Translate:
on a market profile chart, modifying the ln:123 parameter does not work:
closing range time length in minutes = 5 by default.
Do you have the Input for Highlight Closing Range on TPO Profiles set to Yes. Without this, changing the number of minutes will not do anything. Refer to the following:
Time Price Opportunity (TPO) Profile Charts: Highlight Closing Range on TPO Profiles
[2022-11-08 14:37:03]
hello
sorry, may be i have not been precise enough.
in the attached image, I have framed the line defining the closing period in dotted red. even if the "highlight" parameter is activated, we will always be on on 5 time range of 1mn as shown by the use of the crossHair tool (which I have reproduced here).
on the other hand, the closing bar in gray evolves well according to the settings.
note that these 5 periods of 1 minute are found regardless of the settings of the parameter "closing range time lenght in minutes" in a spreadsheet export.
Cordially
imagesupportSierra.png / V - Attached On 2022-11-08 14:23:01 UTC - Size: 104.9 KB - 208 views
[2022-11-08 16:17:57]
We are not understanding this. Here is the documentation for that setting:
Time Price Opportunity (TPO) Profile Charts: Closing Range Time Length in Minutes
It does work properly.
Also the timescale on a TPO profile chart is not accurate. It must be disregarded. Refer to:
Time Price Opportunity (TPO) Profile Charts: TPO Chart Time Scale
