Date/Time: Fri, 13 Nov 2026 21:56:29 +0000
NaN
View Count: 1053
| [2022-11-04 19:58:10] |
| User357195 - Posts: 204 |
Hello SC: If I put a Stochastic Percentile indicator on my chart, it loads fine. Then I used the color background study and added the code in the Alert tab area and then the background colors display as I want. However, now if I try to remove the colors, the Stochastic Percentile disappears, and NaN is shown on the right chart value column. My value format is set at .01. It is an ES chart. I am using Win 11. Not sure if that has anything to do with it. Sierra Charts are the best, in my opinion. Thanks in advance. |
| [2022-11-04 21:45:42] |
| John - SC Support - Posts: 48527 |
Try resetting the scales and see if that resolves it. Refer to the following: Chart Scale and Scale Adjusting: Resetting the Scale For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
