Date/Time: Fri, 13 Nov 2026 22:08:39 +0000
adjusting tick bars
View Count: 701
[2022-11-04 13:35:49]
J.A.Z - Posts: 6
The window I'm trying to adjust is a tick bar.
When holding "control" and scrolling in the price column, it used to just adjust the height and scale of the bar. I could have any time along the bottom, just the height of the tick bars would change.
after an update to version 2448, when doing the same button move, the time at the bottom of the chart stretches as well leaving short bars and less bars to read.
I am looking for the time at the bottom of the window to stay put, while adjusting the tick bar size.
[2022-11-04 14:07:04]
How are you doing the scrolling?
[2022-11-04 14:39:18]
J.A.Z - Posts: 6
I figured it out. Right clicking in the price column, the scale range reset. I changed it automatic and it works as it did. Thank you all, SC is the best!
