Date/Time: Fri, 13 Nov 2026 22:08:34 +0000
Moving average/VWAP wont move with candlesticks
View Count: 710
[2022-11-03 23:20:38]
User264013 - Posts: 2
When i scroll my candlestick chart, the moving average/vwap stays static when i move my chart up/down. it also wont scale with the candlesticks once i adjust the scale.
imagevwap.png / V - Attached On 2022-11-03 23:20:09 UTC - Size: 85.62 KB - 257 views
[2022-11-04 13:55:38]
The scale of your VWAP is not set to either Automatic or Same as Region. Refer to the following:
Chart Scale and Scale Adjusting: Scale Range (Scale Settings)
And refer to the following for how to change the scale of a study:
Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study
