Date/Time: Fri, 13 Nov 2026 22:08:36 +0000
delta percentage
View Count: 1979
| [2022-11-03 20:24:35] |
| mapan123 - Posts: 10 |
my delta percentage doesn't show real value https://www.sierrachart.com/image.php?Image=1667507048663.png |
| Attachment Deleted. |
| [2022-11-03 21:46:39] |
| John - SC Support - Posts: 48527 |
Your Delta Percentages are correct. For example, the first bar visible to the left shows a delta of -1056. Since these are 10000 volume bars, the percentage is calculated as 1056/10000 = .1056 or .11 when rounded to 2 decimal places (or 11% in percentage). If your issue is that the percentages are being displayed as decimals instead of percent (.11 instead of 11%) then this is because you have the Numbers Bars Calculated Values Input for Display Percent Values as Decimal or Percentage set to Decimal. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
