Date/Time: Fri, 13 Nov 2026 22:08:40 +0000
Change open order, DAY to GTC
View Count: 774
| [2022-11-03 20:17:24] |
| OriolCasas - Posts: 190 |
Hello, I have a position on (sim, do not have to worry) I forgOt to check if it was on DAY or GTC and I've found now that it is on DAY. I want to leave the position overnight, how can I change the open order from DAY to GTC? Thank you |
| [2022-11-03 21:31:45] |
| John - SC Support - Posts: 48527 |
You can not change it within Sierra Chart. You would have to close the one order and then open another.
