Date/Time: Fri, 13 Nov 2026 22:08:42 +0000
CET daylight savings
View Count: 748
| [2022-11-02 17:34:51] |
| OriolCasas - Posts: 190 |
Hello, As I am an european citizien. Daylight savings took place last Sunday. I have a ton of customized indicators set up with a different time during the next two weeks. How can I change the settings so I don't have to go through every indicator and change the time settings? Thank you |
| [2022-11-02 18:04:18] |
| John - SC Support - Posts: 48527 |
We do not know enough about how you have your indicators setup to know what would work best for you. But, going forward, we recommend that you keep your charts set to the time zone of the exchange of the symbol. This way you do not need to be concerned with when the Time Change occurs. Refer to the information at the following link on this topic: Time Zone Setting: Resolving Differences with the Transition To/From Daylight Savings Time in Different Time Zones For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
