Date/Time: Fri, 13 Nov 2026 22:08:42 +0000
Trade activity log is doubling my wins and losses
View Count: 717
| [2022-11-02 14:48:13] |
| User203781 - Posts: 55 |
The global setting calls for one contract per trade, and the trade activity log shows only one contract being traded. Yet it is reporting trade profits and losses for two contracts. For example, a recent short was reported as having made +81.00 when the entry and exit prices were only 40.50 points apart, and the number of contracts in and out was reported as 1. Help, please? |
| [2022-11-02 15:22:55] |
| John - SC Support - Posts: 48527 |
Check your Chart >> Chart Settings >> Symbol >> Currency Value per Tick and ensure that this is set correctly. Refer to the following: Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-02 17:10:13] |
Yes, thanks. That is correct.
| [2022-11-02 17:12:28] |
Oh. I have it set to report points, not dollars.
| [2022-11-03 16:35:26] |
Any thoughts? This issue is not mission-critical, but it is annoying, and it induces a small element of uncertainty that I do not need in this activity.
| [2022-11-03 17:46:11] |
What is the symbol you are trading? If you have an entry in the Chart >> Chart Settings >> Symbol >> Trade and Current Quote Symbol, what is it? What is the Chart >> Chart Settings >> Symbol >> Currency Value per Tick set to? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-03 17:46:51
