Date/Time: Fri, 13 Nov 2026 22:08:42 +0000
Limited labels alignment options in Tools Config
View Count: 672
| [2022-11-02 10:58:43] |
| BillyVLLR - Posts: 16 |
Hi support team, I realize that the label alignment options in Tools>Tools Config are quite limited compared to those in Studies>Subgraphs. As a result, the labels on the Horizontal Lines are not as visible as those on the Studies Subgraphs. Would it be possible to add the same options available in Studies>Subgraphs? I have added some screenshots, I hope this will help you. Best regards, Billy |
| [2022-11-02 14:05:13] |
| John - SC Support - Posts: 48527 |
We have set this as a Feature Request. Keep in mind that we do not know when, or if, we will get to this, or any, particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-02 22:24:08] |
Thank you John!
