Date/Time: Fri, 13 Nov 2026 22:08:37 +0000
[User Discussion] - I can not see the poc volume line
View Count: 1038
| [2022-11-01 22:13:52] |
| User285770 - Posts: 41 |
| [2022-11-02 13:49:51] |
| John - SC Support - Posts: 48527 |
You can not use the TPO Value Area Lines study on a TPO chart. Refer to the information here: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart You have options to display the POC directly within the TPO Profile study, which should be able to give you what you need. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Highlight TPO POC For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-03 22:02:29] |
I'm sorry but you misunderstood me. I want to see a bold line on the volume profile not on the TPO Now I marked with an arrow |
| [2022-11-04 13:42:00] |
You still can not use the TPO Value Area Lines study with a chart that has the TPO study on it. To see the POC line on the Volume by Price you need to turn it on in the Volume by Price study. Refer to the inputs for the Point of Control starting with the following and the one below it: Volume By Price Study: Highlight Point of Control There is a link in the above section for the POC color which will give you information on how to change the color and line thickness if you need to see it more clearly. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
