Date/Time: Fri, 13 Nov 2026 22:08:34 +0000
chart dom clearing volume
View Count: 757
| [2022-11-01 19:30:12] |
| jakeybleez - Posts: 56 |
hello, my chart dom volume is clearing whenever a new position is started. I've never had this happen before. is there a setting I am missing? or is it something else thank you for your time |
| [2022-11-01 21:38:19] |
| John - SC Support - Posts: 48527 |
There is a setting to clear the Current Bid/Ask volumes on a new position. Refer to the following: Global Trade Settings Windows: Clear Current Bid/Ask Volume on New Position (Global Settings >> Chart DOM Settings >> Other >> Other Settings) If it is not the Current Bid/Ask columns that are resetting, then which columns are they? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-02 13:27:15] |
thank you so much! i feel stupid i thought that was for the recent ask/bid volume. is there a setting to hide the numbers on the DOM's total volume bars? I cant find an option in the graphics settings to disable the total volume text. nor could i find anything under "current traded total volume" under Chart Dom Columns to hide the text thank you so much for all of your help! -JB |
| [2022-11-02 14:39:27] |
There is not an option to hide the volume numbers. The best you can do is set the volume numbers color to be the same as the column background, but even in doing this, when the Volume Bars are long enough, you will see the numbers displayed.
| [2022-11-03 12:52:29] |
ahh okay. i thought so, bought you never know. Sierra Chart can almost to everything and anything someone has thought of haha. i love it. well anyways thank you and i hope you have a great day! |
