Date/Time: Tue, 29 Sep 2026 13:30:26 +0000
Error saving downloaded files to local system.
View Count: 768
| [2022-10-27 17:13:57] |
| User187858 - Posts: 12 |
new computer running windows 11 via Parallels which has always been my sierra charts setup. for some reason while downloading the software directly from this website i keep getting a sierra chart installer errow ( photo attached ) I also sent the error log from the home instal screen over to the dev's for review. What steps am i missing here to be able to go through with the proper installation? This has never happened to me before as the download / install process is pretty straight forward. |
| [2022-10-27 18:07:44] |
| John - SC Support - Posts: 48046 |
We do not have any experience with Parallels so we can not say. We recommend using the Zip installer instead. Refer to the following: Software Download: Sierra Chart Zip Installer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
