Date/Time: Tue, 29 Sep 2026 13:36:00 +0000
Attached stop to breakeven - followed by a trailing stop
View Count: 570
[2022-10-24 21:50:14]
Steve Leon - Posts: 319
Is there a way to create an attached order where you can set the stop to breakeven after a certain offset (step 1) and then have the stop trail the position after that by a specific amount ? I read the documentation and could not see if this was possible.
Thank you
[2022-10-25 14:43:18]
John - SC Support - Posts: 48046
You would really want to use a Triggered Trailing Stop and set the trigger such that the stop will be at the Break Even and then trail from there. Refer to the information here:
Order Types: Triggered Trailing Stop
