Date/Time: Fri, 26 Apr 2024 23:33:39 +0000
Forced shutdown caused by price alerts
View Count: 888
[2014-05-21 19:00:21] |
What version of Sierra Chart are you running? Update Sierra Chart with Help >> Download Current Version. If after updating you still notice the problem, then provide us the steps you are performing which leads up to this problem so we can reproduce the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-21 19:01:20
