Date/Time: Tue, 29 Sep 2026 15:03:19 +0000
trades on 2nd instance charts
View Count: 642
[2022-10-21 17:47:06]
rondawes - Posts: 51
Is it possible for trades made on a primary instance to show on the charts of a second instance?
[2022-10-21 19:17:28]
John - SC Support - Posts: 48052
As long as you are using a sub-instance, then if the sub-instance is set to not be in Simulation Mode, then the trades will show on there. Refer to the following:
Using DTC Server for Data and Trading in Another Sierra Chart Instance: Viewing Trading Data in Sub instance from Main Instance
Or, if you are using the Teton Order Routing Service, then you can be on completely separate installations and as long as the installations are connected to your Teton service then you will get the information into the other installations.
